Hi Guys, I'm new around here, hence I don't know if I posted this in the right sub-forum...
I currently have got a DLT from a client, however, I need to extract the DDP 2.0 image from the DLT tape. Any software that I can use to retrieve the DDP image?
Thanks!
NovaXchange is the most common - novastor also makes (it is not on their website) some other DLT apps ... http://interchange.novastor.com/datasheets/di_tpu.html
NovaXchange v3.1 with TAR/CPIO Plug-in
MSRP: $1,295.00
also you can use the same authoring app that wrote the image in many cases - maestro , DVDA, scenarist, Studio and others all have DLT abilities - though I have found they dont all write the image on the tape the same .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
DDP 2.1 images are handled by GEAR PRO Mastering Edition .
to check if the image meets all DVD and DDP specs is to use a software verification system, like Eclipse ImageVerify.
in fact on reflection - you would be best off just using GEAR PRO Mastering Edition to read the images file (it does restore as wellas write and create) ... NovaXchange is geared more towards a production place that would be getting tapes formated different ways etc ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks BJ_M for your prompt response! The problem that I am facing now is that I'm unable to restore the DDP image on the DLT tape that my client provided us with. I have been using WinTar SCSI for all my back up to DLT needs, however I'm unable to restore the files from the tapes with WinTar SCSI.
Can the Gear Pro Mastering Edition retrieve the DDP images from the DLT tape? I can't seem to find this function on their web page...
Or maybe I need to change my specs!
Gosh! I really do need to change my specs!!
Restore files to hard disk from DLT, Exabyte, or other tape drives.
Originally Posted by apperceive -
it's $700 and MAC only but DVDAfterEdit can do all this just fine.
If your seriously into the DVD business this app is simply the best tool in the world - handsdown.
http://www.dvdafteredit.com/
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 08:13 -
How to calculate signature of DDP images?
By casejustin80 in forum Newbie / General discussionsReplies: 0Last Post: 8th Oct 2010, 02:04 -
Question about restoring C drive from Ghost image
By jimdagys in forum ComputerReplies: 11Last Post: 24th Aug 2009, 14:24 -
Does this mean my DLT is in fact NEW?
By sdsumike619 in forum Authoring (DVD)Replies: 2Last Post: 19th Jun 2008, 23:36 -
What is DDP ( Disc Description Protocol ) ?
By jjulio1 in forum Authoring (DVD)Replies: 1Last Post: 24th Jun 2007, 16:36
