Does anyone know if the latest version of SVCD2DVD will run on the newest release of Windows Vista Beta 2 platform?
Results 1 to 21 of 21
I have heard from users that it does but you may want to wait for confirmation from one of them on here first.
I have VISTA Beta 2 running with .net installed. SVCD2DVD installed just fine, but when it comes to register and i press continue, the little box with my key disappears. Then i click on the svcd2dvd icon again brings up register box again. Same process over and over. Never verifies program, so i cant use it. Any ideas Chris? Or anyone?
Drop me an email - we can try it offline.
Hey Chris i sent you a email 2 days ago..So we can try SVCD2OUT as stated above...Here from you soon.
svcd2dvd 2.1 (Build 2.1.2308) works on vista beta 2 build 5384 you must run as administrator to install and when you reg it you will need your old reg.xml to reg it if you try to reg without file it will error saying can not register program or something similar to that
I tried .Net v.2, with.Net 1.1, and adding 1.1SP1, before, but SVCD2DVD does not go through registration to usable. I tried Vista Beta 2 and found similar respects. Did someone say you can build a xml.reg?
Chris, I don't know how experienced you are about framework. Example, Java can be dissimilar in branches. .Net should have some focused branches to complete objects. I asked this before. Did you cross-branch some of your application?
The security on the beta is a real deal. They have not got recognition in the OS of OS Type. They have all things ... going on with users. They have a UAI that is prompting about every application. I found at least one site UAI. "Organize" features do not look finished. Microsoft OS Betas are always like this -- short of appeal. -
Yes. Downloaded Install only. Installed Everyone (users might foul up regs). email and ID. 11secs. Running. Thank you. I was worried about doing my next project.
To: funwit
Posted: Aug 01, 2006 10:38
Subject: VISTA and SVCD2DVD (Reply)
If you are interested in VISTA I am sharing this information about UAP (UAI?).
Tweak User Account Protection
Posted 12/22/2005 by Steve Sinchak
To cut down on malicious software applications and beginner computer users from changing critical computer settings, Microsoft has included a new feature called User Account Protection, primarily known as UAP. UAP is a great step in the right direction. It can be used to prevent a beginner computer user from making changes to their computer by restricting them from accessing or even saving any changes to critical areas. UAP is also helpful against Spyware and other malicious software because it will require the user to consent to the action, before any system changes are made.
UAP is a good feature but sometimes it is necessary to tweak it a little so that it is less annoying for more experienced users. For example, an advanced user may be overwhelmed by the number of pop up authorization they receive. By tweaking the settings they can reduce the number of those they see as well as completely disable UAP. Although I do not recommend you completely disable UAP, you can fine tune it to be easier to get along with.
1. To get started, open up the Local Security Settings MMC to show the local security policies by running secpol.msc.
2. Navigate through Local Policies and Security Options.
3. Scroll through the list on the right of the various security settings until your reach the User Account Protection settings. Refer to the list below of the various settings, to change them, just right click and select Modify.
User Account Protection: Behavior of the elevation prompt for administrators
No Prompt
Prompt for credentials
Prompt for consent
User Account Protection: Behavior of the elevation prompt for standard users
No Prompt
User Account Protection: Elevate on application installs
Enable
Disable
User Account Protection: Run all users, including administrators, as standard users
Enable
Disable
User Account Protection: Virtualize file and registry write failures to per-user locations
Enable
Disable
If you want to completely disable UAP, Select No Prompt or Disable for all of the settings.
*** Read that NET has security. Could you include some here if applicable?
_________________
Programming not so hard if you try. Systems won't work the way you want. Sense isn't for an Analyst to grasp. -
It worked fine on RC1, but on RC2 I just get a .Net error:Originally Posted by dallastx
"Unable to find a version of the runtime to run this application"
Installing .NET 1.1 doesn't seem to help. -
Drop me an email and you can try a .Net 2 build which seems to work on Vista RC2...Originally Posted by jmiSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I just installed Windows Vista RC1 5600 and when i launch the installed it says i need .net framework. however, I downloaded the current .net framework and when i went to install Windows said It already installed. tryed to launch the installer again....no go
It s a shame...I love the program and paid for it. but gotta stay up to date
What version of the framework did you install?Originally Posted by dammit32
When Vista is RTM - i will be up to date...but gotta stay up to dateSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
For the version of SVCD2DVD availiable on the website you need .Net 1.1 and then you need the SP1 to the framework too.
If you would like to try the .Net 2 build of S2D then drop me an email...SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I would like to try .Net 2 build on Vista, could you let me know a place to download?Originally Posted by ChrissyBoy
@DunDun
Have you tried this?Originally Posted by ChrissyBoyDwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
The Vista (RC2) build of SVCD2DVD will be available soon... Just waiting on one or two things. Initial tests/feedback is encouraging...
I will be one happy guy when the RC2 version comes out. I am stuck in the mud waiting
SVCD2DVD + Vista
By davezim in forum Newbie / General discussionsReplies: 4Last Post: 18th Aug 2009, 01:02 -
SVCD2DVD 2.5.5030 Not Working with Vista SP2
By k_vic in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 28th May 2009, 12:33 -
SVCD2DVD Vista problems
By blondeguysteve in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Nov 2007, 09:35 -
svcd2dvd with vista
By nigeltheparrot in forum SVCD2DVD & VOB2MPGReplies: 17Last Post: 8th Jul 2007, 06:16 -
svcd2dvd / vista registration issue
By simonlee in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 24th Jun 2007, 14:54
