I used TMPGEnc DVD Author 1.6. I authored and created a DVD folder with my .VOB video files then burned onto a DVD-R 4.7 120min. When trying to play it in my Sony DVD player it does not work, same with my PlayStation 2. Is there something I need to do? or not do? What do i need to do?! Ha
Thanks, Tim
Does TMPGEnc DVD Author 1.6 support your DVD Writer? It doesn't support them all and it's an old version of the program.Version 2 might support your DVD Writer.
Does your DVD Player like DVD-R? Most do,as its a very compatible format.You could try a DVD+R and change the booktype to DVD-ROM,that's if your writer supports this.
Alternatively you could convert your DVD Video Files to an Image file (ISO/UDF) with ImgTool Classic and use IMGBurn to burn to DVD-R.This works for most people AFAIK.
Lastly do you have good media eg Taiyo Yuden or Verbatim (MCC) media? Crap media is usually the cause for playback problems and there is a LOT of crap media about.I find burning the media at half its certified speed best eg 8x media burn at 4x ect...
Try this and get back to us if you encounter the same problem.~Luke~
How to author & burn a DVD from VOB trailers/files
By Baldrick in forum User guidesReplies: 62Last Post: 30th Sep 2011, 06:39 -
Does re-authoring VOB files with TMPGEnc DVD Author, or DVD-lab better
By MarcMiller in forum Video ConversionReplies: 6Last Post: 16th Nov 2010, 01:31 -
Create DVD with TMPGEnc DVD Author 3 and not read on DVD Player
By Salutatous in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 11:22 -
Downloaded VOB, BUP IFO files won't play in dvd player
By COOPERMAN100 in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2007, 06:31
