Hey all,
I've been trying to convert a couple of discs from PAL to NTSC and AC3machine distorted one of the discs (need to check the others). At one point, there's a loud crash of thunder and a plane flying by. There is a crackling (almost farting?) noise in each of the speakers. Any reason why this would be happening? Any way around it??
I've uploaded a clip for you guys to check out. Maybe you can help.
http://www.megaupload.com/?d=SA7GU7SI
Additionally, I did try the "auto find maximum gain" feature as someone suggested but it really only scans the first 6 minutes (I believe) of the audio and then starts transcoding. Is that normal?
name/cause of this video distortion?
By spiritgumm in forum Newbie / General discussionsReplies: 8Last Post: 29th Mar 2012, 11:24 -
How to Convert AVI to DVD + AC3 with CCE and AC3Machine
By ta2 in forum User guidesReplies: 40Last Post: 21st Jan 2010, 18:01 -
No Dolby Pro Logic from AC3Machine
By jonghyunchung in forum AudioReplies: 9Last Post: 28th Jan 2009, 14:35 -
Problems With AC3Machine
By jonghyunchung in forum AudioReplies: 2Last Post: 24th Aug 2008, 15:36 -
So much noise/distortion :(
By Lee82 in forum Capturing and VCRReplies: 1Last Post: 23rd Aug 2007, 00:14
