Ive downloaded some movies that are QT avi's they play with MPlayerOSX2 fine but not with QT6.5 under 10.3.9
they won't open in QT if I click on their icons, I get the beach ball and eventually force-quit.
any ideas? Id like to learn why. don't know how to tell you what the movies are as I can't open then even in finder, the get info hangs.
cheers
rotuts
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
MPlayer OSX will show some media info when using the (i) button in the playlist window. That may help finding out what codecs are used.
It could be the Get Info window hangs because QuickTime is used for the Preview part of the Get Info window. Close that part by toggling the triangle with a Get Info on another (non-media) file. -
You need to install the relevant Quicktime components (to whatever codecs were used in creating the AVIs), for Quicktime to be able to play the videos. mplayer and VLC use their own codecs.
VLC has a file information/properties dialog that can tell you more information about the videos and what audio/video codecs they use. I'm not sure how (or if) the OS X version of mplayer does it, as I never really used it.
The codecs you're most likely to encounter are probably DivX and XVid. You can find the DivX Quicktime component at http://www.divx.com/divx/mac/codec/ . For XVid, there's more than one QT component, and I'm not sure which I'd recommend. Others may recommend 3ivX, but I'm not sure about it, personally.If cameras add ten pounds, why would people want to eat them? -
you were i think correct. on opening the two items in VLC the video component is XVID. in my library->QT-> I have 3ivx D4 4.5.1 for OSX and AC3 codec for macOSX and AC3 Codec.component and a folder Divx Encodeer.component -> DivxEncoder.
the audio for the two files: via VLC: codec a52
is my 3IVX dated? should I look for somthing else? Im happy to play the files in either VLC or MPlayer, but would like to learn why QT fails here for me
cheers again
rotutMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
rotus,
more than likely your AC3 decoder is.
3ivxD4.5.1 still works great for most of my xvids,
all my DIVX process through the DIVX 6 components that came
with Toast 7.
Go get the new one, released oh, a couple of days ago
STF for the link."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
How do i play these mov files?
By perfection in forum Software PlayingReplies: 3Last Post: 11th Sep 2010, 16:42 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 13:10 -
How do I play/convert .MP4 files to play on my laptop
By tfoster in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2008, 21:23 -
Some video files and movie files won't play
By jyeh74 in forum Newbie / General discussionsReplies: 8Last Post: 21st Feb 2008, 11:08 -
Cropping and Resizing Make Video x10 Larger?
By InSaNiTy in forum EditingReplies: 2Last Post: 6th May 2007, 17:29
