Hey Guys,
I'm trying to get TMPGEnc DVD Author 1.6 to create a 16:9 menu, I can only get it to create a 4:3 one.
If I import a 16:9 source it sees it as that, and the menu icons show up as 16:9 but I can't work out how to actually get the menu to encode in 16:9.
If I make the menu and burn it to dvd, on a 4:3 TV the menu displays full screen, then when you click the icon of the video you want it runs in 16:9.
Help! Thanks.
From what I can see o their site, you cannot create 16:9 menus with tmpgenc. However, if you use correctly stretched files for the background, there is no reason you cannot change the aspect ratio of the disc after compilation. There are many programs to do this, including IFOEdit, PGCEdit and DVD Patcher
Read my blog here.
But then you can only use the menu on a 16:9 screen...
On a 4:3 TV the button highlights will be 'displaced'. For 16:9 menus one (or two) additional (letterbox and/or PanScan) set of buttons are necessary.GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Thanks guys,
Thats a shame...I do have Adobe Encore...guess I'm going to have to learn how to use that!
Thanks.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
TMPGEnc DVD Author 1.6...
By acid_burn in forum Authoring (DVD)Replies: 4Last Post: 21st May 2008, 22:45 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
