First post & defo a newbie to this so please be gentle.
I have used Isobuster to create an mpeg file from a bin/cue. Tried burning the image to cd using nero5+ but extremely dodgy sound & audio sync. Then used virtual dub to create a wav file & tmpgenc to convert the wav & original mpeg to a usable file.
Unfortunately, due to me only having a cd burner I have to split the mpeg in two & this is where my problems start. The first encode (from 0 frames to middle) works fine but the second encode (from middle to end) freezes the video at the start for about 4 minutes then carries on as normal.
Firstly, what the hell am I doing wrong (I know it's me not the machine) & secondly, is there an easier way to convert the bin/cue file in to a usable mpeg that I can burn as I've managed to get this far with the guides from the site but bin/cue is the first problem I've become stuck on.
Cheers
Rosco
PS I read the sticky on common tmpgenc problems but couldn't find anything that matches my problem
OK, usual spiel about downloading videos, usually things wrong with them, half-assed encodes, VBR MP3 audio, yadda yadda yadda .....
Let's try to rule a few things out first.
You burnt the image to CD and there were synch problems. Was this playing back on a PC or on a settop DVD player?
After extracting the MPEG out using ISOBuster, can you play this MPEG off your hard drive and does the sync problem exist ?
You said that you did two encodes - I'm assuming that the MPEG is more than 80 minutes long (VCD) and so that is why you are splitting ?
Maybe try doing one encode, and then splitting with TMPGEnc's MPEG Tools ?
Or alternatively just alter the video bitrate so that it fits to one CD - provided everything else is left alone, it is still VCD-compliant. You'll probably need a Bitrate Calculator - https://www.videohelp.com/calc.htm is the one I use.If in doubt, Google it. -
Firstly, thanks for replying.
To answer your first question the image I burnt was played back on a set top DVD player. It had no problems playing back through VLC on my hard drive or from the burnt image. Only problem is audio fading in/out & crackling on the DVD player.
Second question, again no problems with the extracted mpeg when playing on PC through VLC.
Right about the two encodes as a fully encoded mpeg would be too big for one 80min CD.
Had a quick look at the mpeg tools & will try one encode & split afterwards. If not then I'll be back to find out more about using bitrate calcs so I can burn to one disc.
Thanks again
Rosco
Video Causing Computer to Freeze
By Ownaholic in forum Software PlayingReplies: 4Last Post: 26th Apr 2012, 13:10 -
freeze frame a wedding video but keep audio going
By ot5707 in forum EditingReplies: 2Last Post: 25th Jan 2012, 13:35 -
.avi movies freeze when video is saturated
By HartsVideo in forum Software PlayingReplies: 21Last Post: 9th Dec 2010, 14:34 -
Video-TS files slow down and/or freeze
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 17th Jan 2010, 05:20 -
Video Freeze after Conversion to NTSC
By gcam in forum Newbie / General discussionsReplies: 6Last Post: 1st May 2008, 11:57
