hi
im going to start using cce but i heard it takes a long time to encode, what can i do to speed up my computer, do i add ram, or cache speed, thanks, i once heard a guy in this forum say it takes a very short time cos he had certain modifications
thanks
Results 1 to 10 of 10
thanks for quickk reply
i have a pentium(R) 4 cpu 3.40ghz and 512mb of ram
are cpu's expensive and are they easy to instal, i.e no soldering or anyhting
thanks -
So all you've got to go on is hearsay and not firm results ?Originally Posted by slimpickins
I don't use it, but all the evidence I've seen says that CCE is actually one of the quicker encoders. TMPGEnc is generally referred to as "the slow one". Of course it depends on if you do filtering and/or you're frameserving, just to mention a couple of possible factors.
But all things being equal, a CPU upgrade is the most beneficial "drop-in" speed increase. If we're talking about free solutions, then if you have two or four sticks of RAM, you may find that Dual Channel mode can increase performance significantly (increased my performance by around 20%). Make sure both source and destination drives have been defragged. Also it is most optimum if the source and destination drives are on different IDE channels. Of course there's also overclocking as well - but try at your peril.
If filtering is required, then I believe that it is more efficient to filter in AVISynth than using the encoder's inbuilt filters.
Just read your reply above and I don't believe that it would be worth it for you to upgrade your CPU - 3.4GHz is quite fast and there's no value IMHO in upgrading it yet. And no, there's no soldering when installing a CPU - the hardest part is making sure that the CPU is compatible (number of pins, bus speed) with your motherboard. After that it's just a matter of align, drop in, close the latch and bolt the heatsink and fan back on. Then there may or may not be changes required in your BIOS, or possibly the changing of a jumper on your mobo (some models control the bus speed using a jumper, others in the BIOS).If in doubt, Google it. -
hi, what do u mean dual channel mode, and 2 or 4 sticks of ram,?
Be aware , each new cpu release also come's in a couple of flavour's ... the most important factor when considering cpu's is cpu cache memory (built into cpu) ... the larger this number ... the faster it will rip into the job .
Then there are difference's when it come's to system main buss speed ... 100 , 133 , 166 , 200 again , the faster it is here in the sub system , the better .
Here we come across "crippled" pc's ... 200 main buss speed ... crappy celeron used (very small amount of on cpu cache memmory) ... go take dog for a walk ... it might be finished when you get back ... next week . -
Dual Channel mode is where you have "pairs" of RAM working together.Originally Posted by slimpickins
I just googled "What is Dual Channel Mode" and found this:
http://www.intel.com/support/motherboards/desktop/sb/CS-011965.htm
Lots of great info about it there.If in doubt, Google it.
Encoding for faster streaming and MP4Box ?
By Miata in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2010, 20:57 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 23:21 -
How to incr./speed up frames per second faster than 4x in vegas m. studio 6
By ff27 in forum EditingReplies: 1Last Post: 1st Apr 2008, 21:58 -
Increasing Encoding Speed?? What Hardware makes it run faster?
By sandman423 in forum Newbie / General discussionsReplies: 15Last Post: 25th Jan 2008, 23:09 -
How can I make my dvd burner overclock to a faster speed?
By goheadtry in forum Authoring (DVD)Replies: 7Last Post: 2nd Dec 2007, 20:11
