I used ffmpegX to convert to MPEG3 or DVD, then Sizzle to make the disk image (because the files came in two parts) and Disk Utility to burn to DVD-R media.
I have an old Toshiba, vintage 1999 or 2000. It gets disk error, won't even load the menu.
My PS2, also from 2000, will show the menu and when you hit play, you hear audio but no video.
But the burned DVD-R discs play fine in DVD Player (Mac OS X).
Interesting that I got varying degrees of functionality (from none to at least audio).
Is there a particular model I should look for or is it a roll of the dice when dealing with burned media?
I've found that the most compatible DVD recordables are burned with a burner capable of book-typing a DVD+R to DVD-ROM. A NEC-3550A with modified firmware, like mine, will do this. Every Player I've tested will play one of these DVD-ROMs fine.
Burner = around $35
FW case = around $30
Firmware = Free
Compatibility = Priceless
Check it out
recorded dvd won't play on computer or other players??
By wundahoss in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2011, 17:55 -
Burned Video DVD Won't Play in Standalone Players
By adamwolf1965 in forum Newbie / General discussionsReplies: 2Last Post: 1st Jun 2009, 22:21 -
New guy, movies won't play on certain DVD players?
By koreninja in forum DVD RippingReplies: 6Last Post: 12th Oct 2007, 23:53 -
DVD won't play on most dvd players
By green_boots in forum Newbie / General discussionsReplies: 3Last Post: 3rd Sep 2007, 00:12 -
HELP! DVD's won't play on stand alone players
By jessandjeff123 in forum Newbie / General discussionsReplies: 9Last Post: 7th Jun 2007, 07:59
