    Jun 2006
    sacramento, ca. USA
    Hi guys, i'm new at this so bear with me. I have several movies and cooking shows saved to my Comcast Motorola 6412 DVR and i've imported them to my Dell Inspiron 1150 Notebook running Win XP home Sp 2 using CapDVHS program. I followed the instructions to a T, and everything looks fine. However, when i try to use Hdtv2Dvd, i can't import the files to the assets field. I click and drag, but nothing happens. No error message or anything. I know i'm doing it right, because the very first time i tried this it worked, but nothing since. I've also tried to edit the files using Video Redo, but i get an error saying it can't open the specified file. All files are TS, and the shows are about 1.36 Gigabytes, one movie is 1 gig, and the other is 2.4 gigs. I've even tried deleting hdtv2dvd and re-installing it. Any suggestions what I'm doing wrong? Any help is much appreciated.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    What version of HDTV2DVD are you using?
    Jun 2006
    sacramento, ca. USA
    it is version 0.4.
  4. I believe the current version is 0.41, I would download and try that one.
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    Jun 2006
    sacramento, ca. USA
    thanks, i'll give it a shot!
    Jun 2006
    sacramento, ca. USA
    i can't seem to find it. on the website, the download is just ver. 0.4. any suggestions?
  7. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
