We have ffdshow, xvid,divx, 3ivx. They all seem to decode each other's formats...
However, if you install all of them...do they override or mess with the other's codecs?
Once and for all, should I just install 1 mpeg-4 codec? ....if so, which one?
Divx 6, kopei xvid, some other guy's xvid, 3ivx?
If you are just playing back files, you could try mPlayer with the codec pack - it's standalone, and means you do not need to install codecs on to your system.
mplayer doesn't need any extra codecs for MPEG-4 decoding.
ffdshow is the only decoder yuou mentioned that can handle all the fourCC's. I'd still install XviD though since I prefer it over libavcodec for encoding. No reason why you can't have all 4 installed though. 3ivX is out of date, so I can't see much point installing it. The filter with the highest merit will get used for decoding. So if ffdshow is enabled for DX50 and it has a higher priority than the others, it will decode DivX 5 stuff. -
I guess I should have been more specific....I have windows 2000.....and I'm using the old windows media player and media player classic....(I can't stand the new windows media player)....so I can't play mpeg-4 out of the box....
Whats better...ffdshow or divx 6?
Screwed over by a CODEC install
By AveEye in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2012, 05:34 -
Trying to Install Microsoft MPEG-4 Video Codec V1, V2, V3
By eon_designs in forum Video ConversionReplies: 2Last Post: 10th May 2010, 14:03 -
How to install VFW codec alone for VitualDub?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2008, 17:44 -
Missing Codec(s) ... How to find/install/use?
By CaptainChaos in forum Video ConversionReplies: 7Last Post: 18th Oct 2007, 03:47 -
Should I install Canopus Codec?
By tranbuimd in forum Video ConversionReplies: 4Last Post: 26th Jun 2007, 19:01
