I have a video file .avi video 352x288 20 frames/sec data rate 77kbps, audio 96 kbps bit rate mpeg layer-3. I'd like to convert this to ntsc vcd to play on dvd player.
TMPGEnc 2.02 does not recognize the file, it play's fine in windows media player though. Can I and how do I convert this to ntsc vcd mpg file?
option> enviromental setting> VFAPI, set direct show multimedia file reader to higher priority. Then you should be able to load the avi as video source. Decompress the audio with VirtualDub to .wav, load it as audio source.
Since the source has a 20 fps rate, TMPG will add / duplicate frames to get the proper VCD framerate, that's why you may end with jerky playback.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45 -
How to convert my dv-ntsc to gif
By drewdude92 in forum MacReplies: 3Last Post: 23rd Jul 2007, 19:59 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
