i was jsut wondering, since dvd's are 8.5gig and dvd-r's are 4.7 gig, is there a double sided duel layer disk that has 8.5 on each size, i was backing up an er disk and it had like 7gig on each side
Results 1 to 9 of 9
Those are called DVD-18's and I'm pretty sure they don't exist in recordable format. Even the commercial ones are generally very rare.
Agreed. Also, even DVD-10 recordables (single-layer, double-sided) are prohibitively expensive; imagine what DVD-18s would cost.
As DS/DL commercial discs don't span both sides (each side is considered it's own program and has it's own VMG), you can just backup each side to its own DL disc. No "splitting" needed.
Scott -
yea, i've seen the single layer discs like this sell for like 2-3 dollars per disc, i dont wanna know what a dual layer variation would sell for....
True, I just wanted to make sure everybody knew that you wouldn't "shrink" 2 sides the same way you would shrink 1 side, as each side is totally independent.Originally Posted by jimmalenko
Scott -
i know, i couldnt believe it when i went to backup my er disks and each side was 7gig, i hadnt seen that before, i checked and they were different, the set has 4 disks so i guess the set has 60gig
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13 -
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 16:03 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 22:23 -
do they sell double sided, single layer dvd's (DVD-10 - the ones you flip)?
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 24th Oct 2007, 11:40 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 05:04
