I have a series of AVI files, all of them I demuxed the mp3 out and used Sony Vegas to render as AC3 all worked except one.
The one file has 20 seconds of audio then nothing but dead air for the remainder.
I checked the source avi, the sound runs all the way through. I checked the demuxed mp3, the sound is once again fine. I opened it again in Vegas and saw that the sound waves go flat after 20 seconds in the visual representation for the mp3, yet it plays in winamp and everything else fine.
So I demux again, same problem. I demux the wave using VDUBMOD and Goldwave, Vegas wont even open the file, just crashes.
So I try using BeSweet to make the ac3, no errors but still same problem.
So besides finding another source for this file im lost...
any ideas?
All files were VBR and I did the same for all files, only one isnt working.
ok fine - but see the 100s and 100s of posts on sonys forums and here where vbr mp3 doesnt work (as well as mine own experience) with vegas
vegas DID update this in the next to last update for 6 though and it works a bit better - but still not always ....
officially , mp3 (as well as other highly compressed formats) are not considered suitable for editing is sonys position - so only coincidental support is to be found ...
the solution i gave above is one of a couple of working options ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Ok so what I did is convert the whole thing to an mpeg, then demuxed the audio with TMPGEnc, ran the audio through goldwave to convert to a 48khz wav, then ran the wav in Vegas and boom it all worked out fine.
So just for curiosity sake, what about VBR and vegas doesnt work? Does it spit errors out? All my files have always worked never received an error, and I check my files to make sure they all work, is there something in particular I should be looking for?
Thanks! -
hit or miss - not sure what ...
ones that dont work will either lock up or show as very short ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I need help playing AC3 audio file with an AVI
By mark85h in forum Newbie / General discussionsReplies: 8Last Post: 18th Feb 2011, 16:04 -
Avi file wont play when playing with .srt subtitle
By cudencuden in forum SubtitleReplies: 2Last Post: 25th Mar 2009, 21:40 -
trying to convert avi w/ dolby ac3 audio and it wont sync right
By cduval04 in forum Video ConversionReplies: 2Last Post: 14th Jan 2009, 19:40 -
Newbie making good progress with 1080i content needing expert advise
By djdrock in forum Video ConversionReplies: 20Last Post: 27th Jun 2008, 12:01 -
Need an expert advise on converting AVI (or SWF) to MPG High quality video
By oavs in forum Video ConversionReplies: 10Last Post: 10th Jul 2007, 15:41
