    Apr 2006
    Grenada
    If i am intending to burn more than one dvd, is it best to place an editted copy unto a dv tape and then extract the movie from the dv tape. I heard this from someone. He said it would preserve the quality
    How's My English?
    USA
    If you don't have the room on your hard drive to keep the DV, then a DV tape would be a good option. Saving the DV on tape is good if you plan to re-edit it or re-encode it in the future, maybe to a different format. But if you just need a second or more copies of the DVD, then just use the DVD and make a copy of it directly. They are both digital formats, so no losses should occur using either method.
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Plus its faster to burn to dvd. Isn't a transfer of video to dv realtime?
