Sorry guys, but I couldn't find a strdight answer for this one. I have a movie clip in 3ivx .mov format and I want to burn it to DVD. Im at a complete loss though as to how to do this. Help!!!
Results 1 to 10 of 10
Wow this is a fantastic problem except it keep crashing on me. I set the output file to VOB DVD Compliant, change the rez to 740480 and frame rate to 29.97 (I'm NTSC). It gets about 3/4 of the way done, and then I get an error and it stops. Am I doing something wrong?
what error ?
I/O error. It doesn't say anything other than that. When I load my video clip, do I have to leave it on the default output setting? Should I be converting it to something else, like DivX? Thats easy to burn to DVD.
well most anything is easy to burn to dvd - but depends on how you want to play it ...
I/O error means usually bad frame, bad file read or out of room on target drive i suspect ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Th problem is that I dont want to lose any more quality than is actually needed. The actual clips resolution is messed up. It's something 740x5-something. And the framerate is only 25. But playing it on windows media player looks like 16:9. But opening it in Tmpgenc shows it as 11:5. What kind od of f****d format is this? What do recommedond I do as far as output and options if I want this as a DVD with a 740x480 rez, 6.1 sound AC3 sound, 40000/364kbs, 16.: aspect, and 29.97 output?
well - that makes not a lot of sense ...
you mean 720x480 with top and bottom borders - 11:5 is a film resolution ...
5.1 audio , 48,000 sample rate, 448 bitrate and 23.976 frame rate (progressive) + pulldown
super will do all this except the 5.1 audio i believe ... but if the source was 2 channel (most likely) , leave it at 2 channel ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Well the input clip isnt 720x480. It's 720x5-something. It's some weird resolution I've never seen before. Doesn't it need to be 720x480 to be dvd compliant? Also, 11:5, I've never heard of that spect either. The movie itself plays like a widescreen in windows media player, and thats the way I want to keep it. But again, Isn't DVD compliance 16:9? That's my TV ratio, and even if 11:5 worked, wouldn't it look weird? Finally, I have an NTSC and 29.97 is standard. Wouldn't 25 be likw slow motion or choppy? Also, I thought that 3vix and divx all used 5.1 (or 6.1).
your input is pal - 720x540
your frame rate is pal - 25 fps
you are converting to ntsc and the ratio suggests to me that it is a progressive source ...
11:5 (2.2:1) is a film ratio - when you convert to 16:9 , it will have top and bottom borders - not uncommon .. or stretch it and crop it ..
ntsc is indeed 29.97 , but progressive sources are encoded to 23.976 and pulldown is added to makeit 29.97
3vix and divx do not all use 5.1 - in fact most prob. do not (who knows) , 3ivx is most likely 2 channel ... gspot will tell you ..
so will super ..
super will convert pal to ntsc .... another very good program is divxtodvd to do this"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 02:35 -
3ivx question
By Gary Esposito in forum Newbie / General discussionsReplies: 6Last Post: 17th Jul 2009, 18:04 -
3ivx Batch Conversion Available? Possible Script?
By fitch.j in forum Newbie / General discussionsReplies: 2Last Post: 12th Jun 2009, 06:24 -
3ivX to XviD problems...
By GangstaRap in forum Video ConversionReplies: 8Last Post: 6th May 2007, 12:25
