I am in the early stages of video management. Right now all I want to do it crop and split some videos that I have captured over the years. There are usually multiple videos on one DV tape so I capture the entire tape and go back and edit later. Now I'm getting to the editing part. I really just want to crop and split them at this time. They will be primarily viewed on the computer so right now I just leave them as raw DV because it is the best quality. I use WinDV to capture because it is the easiest. Is there a simple tool out there that I could easily and quickly crop movies with and still export it to DV?
I imagine virtualdub will let you output to dv. It can cut and join. (freeware). Also I believe windows movie maker lets you output to dv (xp only).
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Hi kman22,
VirtualDub is free and will do what you want it to. Open your AVI in VirtualDub to work with it.
Any "manipulation" is done by the use of filters: Click Video -> Filters... and choose the ones you need.
To output back to DV AVI, download and install the Panasonic DV Codec (if you haven't got it already) - it too is free and works well with VirtualDub. To use this when exporting, click Video -> Compression and choose it from the list of different codecs.
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Basic Edit from Subtitle Information
By none295 in forum EditingReplies: 1Last Post: 18th Mar 2010, 13:59 -
HELP! Capture with MAC but I need to edit with a PC!
By blainedepue in forum Video ConversionReplies: 2Last Post: 27th May 2009, 10:39 -
Use a MAC to capture...Use a PC to edit? Help!!!
By blainedepue in forum Video Streaming DownloadingReplies: 1Last Post: 27th May 2009, 02:43 -
Basic and Good DVB-T Capture Tool
By wiak in forum DVB / IPTVReplies: 0Last Post: 9th Jan 2008, 10:30 -
8mm camcorder capture to dvd via EasyCap + Ulead - basic query
By deaglan1 in forum Newbie / General discussionsReplies: 2Last Post: 13th Dec 2007, 15:05
