I'm using DVD Decrypter to read ISO to backup DVD's and then Burn with IMG Burn, but for some reason IMG Burn keeps prompting me for the MDS file. Any ideas.
An MDS file is just like a "cue-sheet", which provides IMGBurn with info on how to burn the ISO file. There's just a setting in DVDDecrypter > Tools > Options > ISO Read Mode that says "Create MDS file" that you need to tick, and then re-rip and all should be fine.Originally Posted by cpayne76
Alternatively you can tell IMGBurn not to look for the MDS file and just accept the ISO file as-is:
Either way should work fine.If in doubt, Google it. -
DVDDecrypter (3.5.4.0) => Tools => Settings => ISO Read Mode => check "create MDS file"
(oops, should've waited for the images to load
Trev -
Equally as important....ImgBurn does not need to have the MDS file to burn.
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 12:44 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 13:21 -
DVD Decrypter to ISO file - missing
By mkr10001 in forum DVD RippingReplies: 4Last Post: 5th Jan 2011, 18:55 -
Problems Creating ISO with DVD Fab Decrypter
By ViRaL1 in forum DVD RippingReplies: 1Last Post: 25th Jan 2009, 13:30 -
Standalone DVD Player to read iso image and VTS files
By bluemoss in forum DVD & Blu-ray PlayersReplies: 6Last Post: 19th Nov 2007, 15:45
