I can't back up the DVD-Rom portion of a music DVD. I've tried using both DVD Decrypter and DVD Shrink, but neither worked for this portion of the back up. Is this even possible? The DVD has Interactual Player on it. Is there something I need to change in the settings?
Thanks,
Have you tried copying the folder via "my computer" if its a pc? I believe the data files should just be drag and drop. I did that with the first Matrix dvd.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
The original poster is looking to get the DATA portion of the dvd copied. That is usually things like webpages, screensavers, and computer games. Those should be able to be drag-and-dropped on to the computer without much hassle as the designer of the dvd wants you to be able to use them without much hassle.Originally Posted by ki.cheukDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Thanks, I was able to get to the files in Nero by just dragging and dropping.
Bombono DVD 0.5.10, new features
By ilya in forum LinuxReplies: 2Last Post: 24th Nov 2017, 15:12 -
Moving back iTunes Music folder
By mccoady in forum ComputerReplies: 5Last Post: 16th Nov 2009, 22:28 -
Advanced DVD features
By Grov in forum Newbie / General discussionsReplies: 8Last Post: 9th Jul 2009, 11:08 -
Play back Music Videos In My Car
By trevz87 in forum Portable VideoReplies: 6Last Post: 22nd Mar 2009, 19:58 -
Clicking noise while listening to music on CD-ROM
By WishMaker in forum ComputerReplies: 6Last Post: 25th Jul 2008, 03:52
