  1. I have 20 minutes DV avi material.
    I just want to trim. Does this script is OK for trimming interlaced source?
    avisource("C:\Documents and Settings\My Documents\Video 1.avi")
    Trim(0,27450)
    thanks
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Looks fine to me.
    Provided frame 27450 is your end frame, of course. Also don't forget that AVISynth will serve uncompressed video and PCM WAV audio to your application of choice, so you may need to choose some compressions.
    If in doubt, Google it.
  3. I work with CCE. That script i load in CCE and make mpeg2 720x576x25, audio make in ac3.
