No matter what setting I try, best I can get is 16:9, if I select DVD 16:9 in ffmpegX0.0.9w.
The original is 640x272.
If I try "Unconstrained" or either of the 2.35:1 settings (the normal and the "Keep Height" settings, you get a 4:3 stream).
I would have thought you might get a 16:9 frame with further black bars at the top and bottom.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
