Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
    Jun 2006
    Australia
    Hi
    I am having a problem with getting a CD I have burnt on my PC to comply with the "repeat all" function on a stand-alone CD/stereo unit.
    My 2yo son loves a particular DVD of his and I ripped the audio track to a set of wav files and burned them onto an audio CD for him, and he listens to it at night time. Usually with his night-time CDs - including the ones that Dad burns for him - repeat all tracks all night without a hitch, but this one cd, no matter what, doesn't seem to want to do it.
    I am using a Benq generic CD burner and it does all my CDs without this issue, and use Nero express to burn them.
    I have tried the following to no avail:
    - different blank media
    - burning at a slower speed
    - converting to MP3 then converting to ausio Cd with nero
    - joining all the wavs into a single track and using single "track repeat"
    - burning with the CDRW function of my DVD burner
    Does anyone have any suggestions of what else I might try??
    Thanks very much in advance.
    Go Socceroos!!!
    Feb 2004
    Australia
    Try and confirm you are burning audio with a frequency of 44.1hz only ... normal music cd's .
    Use audiocity to convert them to required frequency before burning them .
    Never encode to mp3 and back to wav ... the quality gose down .
    Jun 2006
    Australia
    THanks Bjs
    Unfortunately the tracks are all 44.1hz, so it must be something else.
    Feb 2004
    Australia
    I just ran into a toast sucker ...
    Check the file name's used on the disc that play's fine .
    Then compare that too this new disc you are creating ... might be a file naming issue .
