Hi!
I've been using FairUse Wizard to compress my home dvds to XviD. I use Fairuse Wizard and till now I had no problems. But now I have one. I made a long record so the dvd was record with half width resolution. When I open it in Fairuse Wizard, in the output resolution I'm unable to choose res above 336x256This is because the video is compressed in width, I think.
So, my question is:
Is there any thing I can do to change the aspect of the dvd??
Is there a program other than FairUse Wizard that can make the conversion WITH THE POSSIBILITY OF CUTTING THE PARTS I DONT WANT??
Thanks.
You could use a program like VOB2MPEG to extract out the video from the DVD as one MPEG, then put it into VirtualDub Mod and trim what you want, then encode to Xvid. VDM will also accept VOBs directly, though you would have to joint them to get the whole video. Alternately, DVD Decrypter can extract as one large VOB.
Thanks.
But... the problem is that the video is shrinked horizontally
And another thing. I used virtualdubmpeg but when i try to convert the audio, it says:
"No audio decompressor could be found to decompressthe source audio format"
How can i bypass this???? -
If it's AC3 audio, you can use AC3 ACM Decompressor. You may be able to correct the aspect in VirtualDub by using a filter, maybe Resize. It can't hurt to experiment a little.
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 18:57 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
Burned a 2prt avi to dvd Loss of audio on 2nd part of the movie.
By Ryanmhindman in forum AudioReplies: 2Last Post: 22nd Sep 2009, 14:43 -
Merge 3 part XviD AVI
By Benhermies in forum Newbie / General discussionsReplies: 3Last Post: 5th Jun 2009, 22:45 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 08:36
