I have a program that plays sounds, ie waterfall, stream, waves,etc. They are stored on the computer as NAT files. How can I convert them to mp3 or something that can play on a CD player? Thanks.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
I can find no reference to a audio file type of NAT anywhere. But that is a common term in broadcasting that applies to NATural audio, the background sounds such as traffic, surf, waterfalls, etc., used to fill in the background audio during interviews, etc. You could try dropping one of those into a program like Gspot and see if it is identified as a common audio format.
What program are you using to play them? It could be a proprietary format that only that program uses. If all else fails, make a copy of one and change the extension to a more common audio format. It might take some trial and error. -
Or you could use an audio recorder program that can record "what u hear" off your soundcard in realtime. Then all you have to do is play the file and record it at the same time.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thanks guys, they play with Media classic, but I'm interested in finding a program that will record 'what you hear". Can you help with that. At the moment I'm recording it with my video camera and stripping out the audio.Originally Posted by yoda313
EDIT. Just found a recorder, thanks for giving me the idea."Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
If they play using Media Player Classic, then the solution may be more simple than recording the audio in real-time - the .nat files may simply be renamed wave/mp3/etc. files. What program is using the .nat files? I tried a simple Google search, so I could take a look at the sounds and test this theory, but came up empty-handed. (Of course, my search was probably too vague, anyway.)
If cameras add ten pounds, why would people want to eat them? -
It's a program called Natura sound wave therapy.
When you have the NAT files loaded in Media Player Classic, what information for them do you see under File > Properties > Details tab?
No problem glad to help.Originally Posted by tweedledee
It would be interesting if renaming the file to .wav would work. You should let everyone know if it does.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Converting bluray movie files to low size files
By AndreL in forum Video ConversionReplies: 6Last Post: 7th Dec 2011, 02:06 -
Changing NAT Settings On The XBOX 360
By Nitro89 in forum Off topicReplies: 0Last Post: 8th Nov 2008, 12:49 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 29th Aug 2008, 00:33 -
What is NAT for routers and is it needed for PS3 gaming?
By yoda313 in forum ComputerReplies: 15Last Post: 12th Jul 2008, 10:00 -
Converting AVI files to Video_TS files/ffmpegx V0.0.9Y OS is Tiger.
By sadepussycat in forum MacReplies: 10Last Post: 2nd Jun 2008, 16:43
