Can you backup playstation games the same way as normal dvd movies ??
My kids have use ours all the time and I'm concerned they will scratch them. If so can you still use dvdfab decryptor and shrink ??
Bit wary as I've recently had a hard drive crash and don't want to do anything to send this one into a spin.
Backing up games is the easy part. Getting backups to work properly in the console device is a completely different story.
Not to be rude but this isn't http://www.gamecopyworld.com
I'd suggest you do a forum search for "playstation games" and see what comes up.
I believe you can just do a straight disc copy with PS2 games but as mentioned, you'll need a chip in your PS2 to be able to play them.If in doubt, Google it. -
The best way by far to backup ps2 games is to use dvddecrypter ... iso read mode to copy disk to hdd ... iso write to burn back to a blank dvdr ... works flawlessly everytime ....
As Jimmalenko points out ... you will need to have your ps2 chipped before you can play the backups -
um sorry if this was posted in the wrong place - I'm still not too sure of how things work.
This is all completely new territory - didn't mean to cause any offence.
I did try a search before I posted, but not much came up.
Thank you to those that replied.
How do I get the "ps2 chipped " ??? sorry but I don't know what that means . -
These fellow may be able to assist you: http://www.modchip.com/How do I get the "ps2 chipped " ??? sorry but I don't know what that means .
And as stated, this is a Video Forum. Gaming questions may be better answered at Gaming Forums. You can do a Google search for PS2 sites that can probably tell you everything you want to know.
If anyone needs a reliable mod installer let me know
I know a good one
If you want a quick and simple way if you have an older fat ps2 you can stick a hd on a network adaptor and by a hd advanced disk and save the games directly to your hd without a modchip
Backing up of Wii games?
By freebird73717 in forum Off topicReplies: 6Last Post: 6th Dec 2011, 12:10 -
Backing up my PS2 games....
By SE14man in forum ComputerReplies: 23Last Post: 16th Jan 2008, 12:12 -
Backing up Games?
By LCE in forum Off topicReplies: 2Last Post: 24th Oct 2007, 00:45 -
Backing up EA Sports Games
By drew23977 in forum Off topicReplies: 3Last Post: 19th Jul 2007, 02:09 -
Copy PS2 games
By hummer in forum ComputerReplies: 1Last Post: 25th May 2007, 12:58
