I have about 150 eps of my favorite hour-long (actually they're only about 44-51 min.) tv series on individual DVD's. I've been using DVD Decrypter, DVDShrink and Nero 6 to transfer them 3-up to other disks. I was rolling along until I got to one set that gets what it says is a "burning error". This what the Nero log says:
[08:59:19] DVDEngine ERROR
[08:59:19] DVDEngine cause: 128 (nmc_processing_exception)
[08:59:19] DVDEngine source: DEGuardNMCConversion
[08:59:19] DVDEngine description: SEH EXCEPTION caught during INeroMediaConverter:oConversion().
[08:59:19] DVDEngine ################################################## ######################################
It craps out shortly into the transcoding process on the first episode of the three. It doesn't even get to the burning part. I know it's not the burner because I did another set right after this and it worked fine. Also, it wasn't a bad disk because I used the same disk for the one that worked okay.
If it means anything, these three episodes might have been slightly longer total than the other threesomes. The first one is 51 minutes. The other two are 49 minutes each.
I'm assuming you are using Nero Vision Express. Do a Google search for 'nmc_processing_exception' and you will see that error is fairly common. They also don't seem to know exactly what causes it or how to fix it. Nero is reportedly working on it.
Personally, I only use Nero Burning ROM for burning and none of the other programs in the suite. Nero is not much good at transcoding, encoding or authoring, IMO. But it burns OK.
It would appear that one of those three files is corrupt (or at least something is different about it that Nero doesn't like). Try doing the files one at a time until you can find out which is causing the problem. Then check out that file to see what is different about it.
You could also do the file encoding yourself instead of relying on Nero is only average at best.Google is your Friend
Error messages burning data DVD using Nero version 6
By craigsb in forum ComputerReplies: 6Last Post: 27th Oct 2011, 09:12 -
DVD error while burning in NERO 7
By coinsdrop in forum Newbie / General discussionsReplies: 19Last Post: 22nd Apr 2009, 10:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Error, after burning a dvd with nero
By Remyisme in forum Newbie / General discussionsReplies: 13Last Post: 27th Sep 2008, 02:11 -
NERO gives me error message when burning DVD
By qwazi in forum Authoring (DVD)Replies: 8Last Post: 10th Aug 2007, 01:01
oConversion().
