    Jun 2006
    I have scoured for the answer to this question and have yet to find the correct anser. I have about 15 seperate .vob files that I need to burn to a dvd. I only have the .vob files because I ripped them from 5 seperate dvd's using smartripper.
    What are the steps that I need to take these 15 .vob files and make it so they can be burned in a specific order to a dvd. Thanks in advance for all your help.
    Jason
    USA
    Take a look to the upper left for 'What is' DVD. That will show you the DVD file structure. If all the VOBs are compatible with each other, you may have to rename them in the order you wish. Such as 'VTS_01_1.VOB', 'VTS_01_2.VOB and so on. Then you could use a program like IFOEdit to restore the rest of the DVD structure. Or you may just be able to drop them into TMPGEnc DVD Author as DVD videos and let it create the structure.
    If they differ, which would not be surprising, you may have to convert them back to MPEGs and then author them. This would probably be better if you need to blend the transition between the videos or do any editing. Here's one method: https://forum.videohelp.com/viewtopic.php?t=224833
    And welcome to our forums.
    Jun 2006
    OK I read
    How to author & burn a DVD from VOB trailers/files......
    https://www.videohelp.com/forum/userguides/120021.php
    Here is where I get confused. Where do you repeat the process for VTS_01_002, VTS_01_003, VTS_01_004. Do you do it at the end or in the middle. I guess that is where most of my confusion is right now.
  4. Mod Neophyte redwudz's Avatar
    USA
    You can only have 10 VOBs per title. You will need to do a second title within the DVD for the other 5. I'm not sure what the problem is with the renaming. Do it just like your guide showed. Check the 'What is' DVD for the structure and use that arrangement.
    Folder Files Explanation
    AUDIO_TS (undefined) DVD Audio
    VIDEO_TS VIDEO_TS.BUP
    VIDEO_TS.IFO
    The first video play item, IFO, usally a copyright notice or a menu
    VIDEO_TS.VOB The first video play item, VOB
    VTS_01_0.BUP
    VTS_01_0.IFO Title 01, IFO, usually the main movie
    VTS_01_0.VOB Title 01, VOB 0, the menu for this title
    VTS_01_1.VOB Title 01, VOB 1, the video for this title
    VTS_01_2.VOB Title 01, VOB 2, if larger than 1 GB it will be splitted into several vobs
    VTS_01_3.VOB Title 01, VOB 3
    VTS_01_4.VOB Title 01, VOB 4, up to 10(0-9) VOB files if necassary
    VTS_02_0.BUP
    VTS_02_0.IFO Title 02, IFO, usually movie extras
    VTS_02_0.VOB Title 02, VOB 0, the menu for this title
    VTS_02_1.VOB Title 02, VOB 1, the video for this title
    VTS_xx_x.BUP
    VTS_xx_x.IFO And so on
    VTS_xx_x.VOB
    VTS_xx_x.VOB
    VTS_99_9.VOB Up to 99(1-99) titles with max 10(0-9) VOB files each
