  1. i have a movie that has audio in french ...but it also has the audio in english they r seprate files and the movie is in divx format how can i add the audio in english to that movie..
    USA
    Drop it into VirtualDub Mod and check the 'Streams' to see if there are two audio tracks shown. If so delete the French audio and you should have only the English audio left over. Resave the Divx video with 'Direct stream copy' and you now should have it with English only. If the audio is separate from the video, you can add the English version in and delete the other as above.
