I am thinking of capturing video live straight to my computer, and am thinking of buying the Edirol v4 mixer.
It has 2 Composite video outputs and one S-Video output.
Can I capture direct to my computer using the S-Video output, and will I lose frames?
And more importantly, if the S-Video is "analog" would this mean I lose quality too?
Is there a mixer that simply outputs straight to computer using a Firewire cable?
That way it should be fast enough and remain digital.
Any comments?
The Edirol v4 mixer is a dual TBC with switching and effects to a single output. Inputs and outputs are analog composite or analog S-Video. Use S-Video where you can. It will allow live mixing between VCRs or a VCR and camera or two cameras. There would be some quality loss through the switcher versus a direct DV format feed to the computer. You only need to use the switcher when you must mix inputs live. Frame rate will be the same as any other S-Video input to a capture card. It's probably best to capture uncompressed (or huffyuv) if you don't have a hardware encoding capture card.Originally Posted by Bansaw
If you want a DV format digital switcher, check out the $4,000 Datavideo SE-800
http://www.datavideo.us/products/se_800_main_page.htm
Connecting a Video Mixer
By eightandahalf in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2011, 11:32 -
Video Mixer or fader
By bbbrown555 in forum Newbie / General discussionsReplies: 3Last Post: 10th Feb 2011, 16:30 -
HDMI to Svideo or Composite?
By cdgtcc in forum DVB / IPTVReplies: 1Last Post: 14th Nov 2008, 05:53 -
Composite IN vs S-Video IN (using converter wire composite to s-video)
By goal in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2008, 22:19 -
JVC GZ-HD7 NTSC - i lose frames when compressing to AVI
By Wookiss in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 10th Jul 2007, 08:18
