I have an incomplete (98%) APE file which I tried to convert to WAV using dbpoweramp converter and partway through it stopped and gave me a decompression error. Is there anyway I can convert this entire incomplete file to WAV?
http://www.monkeysaudio.com/download.html
.APE is Monkey's Audio - a lossless audio codec. You may have more success by using their own decompresser.
Good luck! -
I found this on the Monkey's Audio forum:
Recovering 'broken' Apes
You could try using the WinAmp APE plug-in (included as part of the Monkey's Audio installation) set to "ignore bitstream errors" and set WinAmp to write the output to a WAV file. That should recover whatever audio is recoverable.The WinAmp APE plug-in allows you to "ignore bitstream errors", but you really don't want to hear a corrupt APE. Not until you turn down the volume and open all your windows!
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
How to burn or extract some CUE or APE files?
By diets in forum AudioReplies: 3Last Post: 21st Jan 2010, 10:43 -
.flac/.ape To MP3 | I want the Best Result ...
By Benygh in forum AudioReplies: 7Last Post: 12th Dec 2009, 10:12 -
.ape format how to convert to mp3?
By sumeshkri in forum AudioReplies: 5Last Post: 30th Sep 2008, 22:16 -
Problem with APE file
By Gregg in forum AudioReplies: 1Last Post: 3rd Sep 2008, 06:30 -
Cutting avi's with APE 3?!
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 12:35
