    Jan 2004
    Caprica
    Hi
    I brought a music cds Called Classic Euphoria From Ministry of sound ,Universal Music operations Ltd MCPS.
    Anyway I decided to make a back up of them (3cds) for the car.(Before you lot start going on about it must be the pc or the software its NOT.Due to the fact the pc is brand new 2 days old.)
    But when I went to burn the image`s using Alchol 120% or Nero 7 or clone cd something kicks in and slows down the burning process.The first cd burns 10x the second 4x and the 3rd 1x.
    Can anyone tell me how to get rid of this nasty shit.
    Thank you
    Nicebud
    PS Ive even changed the burner from A pioneer A110 to A111.Its still the same.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Maybe try extracting the audio tracks to WAV files using something like EAC or CDEX and then creating a new audio compilation disc in your burning software ?
    If in doubt, Google it.
    Mar 2006
    Australia
    If you have a rootkit this should find it:
    http://www.sysinternals.com/Utilities/RootkitRevealer.html
