anyone?
thanks in advance.
Hi there,
I have a Harmony 676. A quick check of its programming database shows this model listed. It appears to have all of the normal dvd buttons already known/mapped. Is there something odd on this remote that you are looking for specifically? If so I can check the database again for you.
I can't recommend the harmony line enough. This is finally a true universal remote. I have been able to replace every remote in the living room with this one remote. Setup is done via the web and even if it doesn't know your device it will guide you through learning all of your remote codes. I was able to learn the remote for a dlp projector in less than five minutes. It took another 10-15 minutes to map the buttons where I liked them on the remote and then, I was able to put the projectors remote away as well.
The site that Bob W. mentioned above is a great location to lookup info on remotes. Has a lot of user reviews and forums for the different remotes. The only problem is that there is a missing n in central. The link should be www.remotecentral.com
Another link you can try (If your are interested) is the logitech/harmony test drive site. It allows you to use their database to configure one of their remote controls. You can then see if it has all of the devices/codes that you are looking for. The link is here:
http://members.harmonyremote.com/EasyZapper/New/ProcIntroduction/Intro_start.asp?Langu...Type=TestDrive
Hope this helps some.
Portland PVD 1000 DVD player Universal Remote code Needed
By richco in forum DVD & Blu-ray PlayersReplies: 4Last Post: 20th Apr 2009, 17:17 -
Where to find universal remote code for Philips DVP5990/37?
By FredThompson in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Mar 2009, 11:14 -
Universal Remote Control
By titilucky in forum DVD & Blu-ray RecordersReplies: 11Last Post: 3rd Nov 2008, 15:31 -
Trutech TT320
By phil42 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 20th Aug 2007, 21:08 -
DV-DS81E hitachi DVD recorder universal remote code needed
By Dekaspace in forum DVD & Blu-ray RecordersReplies: 0Last Post: 14th Jul 2007, 12:28
