I have ripped home made DVD (from DVD based camcorder) into VOB files on my HDD. However, Premiere does not support VOB files so I used VOB2MPG to convert these files into MPG and then imported the MPG into Premiere, the problem is Premiere seems only recognize the first less then 3 minutes of a 17 minutes clip.
I've been struggling with this problem for many hours and have tried everything I can think of to no avail, please someone help me...thank you!
Michael
Results 1 to 10 of 10
If the edits are simple cuts, and no fancy transitions, you would be better off using a deditcated mpeg editor such as womble.
You don't say which version of Premiere you are using. I believe Premiere Pro 2 can edit mpeg reasonably well, but earlier versions don't like it at all. You are better off converting to DV avi using virtualdub and the Panasonic DV codec.Read my blog here.
To open MPEG2 files on Premiere I first use DGIndex to create a d2v file, then I use Vfapi Reader to make a fake-avi, which I open in Premiere without problems.
Thank you very much for reply, guns1inger and Caple!! I tried both your suggestions and have found Caple's method works better - mainly because the tools are free
This solved my long struggled problem of letting Promiere to recognize my home video, thank you so so much for the help!!!
Michael -
I tried caple's method. I downloaded both the applications and managed to get an avi file but when i tried to import it to adobe premier pro 1.5 it says "unsupported compression in file". What can I do?
Can you play the fake avi using windows media player?
.VOB>adobe premiere 6.5
By IT learner in forum EditingReplies: 1Last Post: 20th Sep 2011, 08:43 -
Steps to edit video in Adobe Premiere Pro CS3?
By LateFate in forum Newbie / General discussionsReplies: 0Last Post: 22nd Apr 2011, 09:21 -
How to edit .WTV files from Hauppauge HD-PVR (H.264/AC3) in Adobe Premiere
By milOtis in forum User guidesReplies: 2Last Post: 12th Apr 2010, 05:04 -
Can I edit HD MOV files with the newest Adobe Premiere or Sony Vegas?
By vatkat234 in forum EditingReplies: 3Last Post: 16th Nov 2009, 18:47 -
Edit a HD project in Adobe Premiere pro 2?
By rajaa in forum EditingReplies: 12Last Post: 22nd Apr 2009, 00:16
