Hello
I am attempting to replace LPCM audio with AC3 before shrinking a DVD in oder to improve the quality of the video
I am attempting to follow the guide as detailed here
https://www.videohelp.com/forum/viewtopic.php?t=234240
however have come across a few problems
I am very new to all this so apologies if the answers to my questions are obvious
I have attempted to follow the above guide however have got stuck at Step 2![]()
I have ripped the DVD to my hard drive using DVD decrypter however when attempting to select the VOB files to Demux using VobEdit I become a little stuck
The DVD itself is made up of 3 episodes and contains a lot of VOB files
VTS_01_0, VTS_01_1
VTS_02_0, VTS_02_1, VTS_02_2, VTS_02_3
VTS_03_0, VTS_03_1, VTS_03_2, VTS_03_3
VTS_04_0, VTS_04_1, VTS_04_2, VTS_04_3
VTS_05_0, VTS_05_1
I am not really sure how to select the VOB files I need. I can select for instance VTS_02_1 which will then start to play the beginning of episode 1 where as VTS_02_02 will play the second part of episode 1 etc
Do i need to Demux all these vobs as they contain sound or is there one vob file that should cover the whole disc? What about the menu if that contains sound?
Any advice you can give would be appreciated
Any menus will be in the VTS_xx_0.VOB file(s). So you can demux them to get the menu audio.
From looking at the file layout I'd suggest that VTS_02 is Ep 1, VTS_03 is Ep 2 and VTS_04 is Ep 3. So you should be able to just demux each VTS in turn. IIRC there's a tickbox in VOBEdit's demux options which says something like "demux complete titleset", which should then continue on with VTS_02_2.VOB and VTS_02_3.VOB in turn.If in doubt, Google it.
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15 -
Converting LPCM , DTS and AC3
By Benjy in forum AudioReplies: 10Last Post: 8th May 2010, 06:20 -
Re-Authoring A DVD With LPCM>AC3 Audio & Fewer VOBs
By DeathStalker77 in forum Authoring (DVD)Replies: 5Last Post: 25th Dec 2009, 12:25 -
Dvd Vobs: change audio from LPCM to AC3 2.0
By biancolone in forum Authoring (DVD)Replies: 3Last Post: 14th May 2007, 07:16
