    Jun 2006
    I'm trying to make a Divx file with 'Normal' audio.
    The source file is DX50 with vorb audio. Toast will not accept this cofig.
    I can convert the Video but I get NO audio.
    Here is what the info file states:
    success: format: 0 data: 0x0 - 0x15e430d4
    [Ogg] stream 0: video (FOURCC DX50), -vid 0
    [Ogg] stream 1: audio (Vorbis), -aid 0
    [Ogg] stream 2: subtitles (SRT-like text subtitles), -sid 0
    [Ogg] stream 3: subtitles (SRT-like text subtitles), -sid 1
    [Ogg] stream 4: subtitles (SRT-like text subtitles), -sid 2
    Ogg file format detected.
    VIDEO: [DX50] 576x432 24bpp 25.000 fps 0.0 kbps ( 0.0 kbyte/s)
    [V] filefmt:18 fourcc:0x30355844 size:576x432 fps:25.00 ftime:=0.0400
    xvid: using library version 1.2.-127 (build xvid-1.2.0-dev)
    Opening video filter: [expand osd=1]
    Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
    Opening video filter: [scale w=720 h=544]
    Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
    Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
    Demuxer info Language already present!
    [Ogg] Language for -sid 0 is '-slang "English"'
    [Ogg] Language for -sid 1 is '-slang "Dutch"'
    [Ogg] Language for -sid 2 is '-slang "French"'
    VDec: vo config request - 576 x 432 (preferred colorspace: Planar YV12)
    VDec: using Planar YV12 as output csp (no 0)
    Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
    SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using AltiVec
    videocodec: XviD (720x544 fourcc=44495658 [DIVX])
    xvid: par=0/0 (vga11), displayed=725x544, sampled=720x544
    : CBR Rate Control -- bitrate=2199kbit/s
    Writing AVI header...
    1 duplicate frame(s)!
    ODML: vprp aspect is 4:3.
    Flushing video frames
    Writing AVI index...
    Fixing AVI header...
    Video stream: 1779.224 kbit/s (222402 B/s) size: 1485652 bytes 6.680 secs 167 frames
    What am I doing wrong? i.e. No audio
    Thanks for the help.
    John
    Jun 2006
    After an entire day of trial and error, I solved the problem.
    1. I used ffmpegX to extract and covert the audio to AC3
    2 I used ffmpegX to extract and covert the video to Xvid
    3. I used D-Vision 3 to mux the two parts back together agian.
    It took FOREVER to figure this out, but problem solved!
    Reklaw
  3. Member terryj's Avatar
    N35°25.24068, W097°34.204
    one sentence:
    Download and install the OGG Vorbis component for Quicktime,
    and next time you can use QT Pro to do it all.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
