When getting technical info on DVDs through Nero, it only shows the type of disk and its capacity, or possibly that a commercial DVD is copy-protected, but is there a program that will also show for instance the bit rate (2 Mbps, 9 Mbps...) of a recorded DVD disk, encoding (MPEG1, 2), resolution (720x480, 352x480...), and similar information? Thanks, tac7
Yes, thanks jimmalenko, GSpot displays lots of info. Now if a DVD has been compressed and backed up using DVD Shrink, is there a way to determine later on what % of compression has been used on that disk?
Recommend fast & small (few system resources) DVD utilities quick analysis?
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2010, 15:37 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
Software for analysis CD/DVD
By grzegorz in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 20:14 -
question about where bad hard drive disk sector info is stored
By jimdagys in forum ComputerReplies: 1Last Post: 20th Apr 2008, 16:24 -
DVD Recorder models - Picture Quality and Features Analysis
By trhouse in forum DVD & Blu-ray RecordersReplies: 113Last Post: 8th Feb 2008, 01:22
