I've downloaded an avi with multiple voices
its not spilt over a left/right, but there are 2 streams according to avi codec, but i can;t seem to find a tool that can let me playback just the one
If you're just looking to play the video, while selecting which language/stream you want to hear, and only that stream, you can also install a splitter (such as Haali Media Splitter), which will let you choose between the streams.
(And the discussion of streams is reminding me of the old quote from Ghostbusters, but I won't go there.)
+1 audio steam to the DVD with original menu.
By kurochocho in forum Authoring (DVD)Replies: 0Last Post: 12th Jul 2011, 10:48 -
Audio out of sync, Batch DVD Steam Converter & Muxman
By assman24 in forum Newbie / General discussionsReplies: 3Last Post: 5th Dec 2008, 16:25 -
Easy way to extract audio (DTS) from a .m2ts stream and convert it to AC3?
By marklight in forum AudioReplies: 1Last Post: 8th Sep 2008, 17:42 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27 -
Extract problem dolby audio from transport stream
By DVWannaB in forum Video ConversionReplies: 7Last Post: 17th Aug 2007, 22:35
