Hello out there,
I just downloaded VirtualDub and I really don't know too much about the program. But I already ran into a problem. I allocated too much disk space and now i don't know how to undo the allocated disk space. Please help.
	I'm not clear on why you would want to 'allocate' space for VD. Do you mean you created a partition on your hard drive?
 What is it you want to do with VirtualDub?
 And welcome to our forums.
	I was in Capture mode and under File there is "Allocate Disk Space...", I allocated close to all of my hard drive, thinking I could just reallocate after but I can't find out how to reallocate, therefore I am running out of disk space. I'm sure there is an easy solution but I can't seem to find it.
 thanks for your help-
	I understand now.  I haven't used that option to allocate diskspace. Have you closed the program and tried a reboot? I'm assuming it set aside some temp file space. But probably someone here that uses VD for capture may have a simple answer. I haven't used that option to allocate diskspace. Have you closed the program and tried a reboot? I'm assuming it set aside some temp file space. But probably someone here that uses VD for capture may have a simple answer.
  Question about how ImgBurn reckons disk spaceBy Seeker47 in forum Authoring (DVD)Replies: 3Last Post: 10th Feb 2012, 17:38
  avstodvd disk spaceBy nhn21 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2010, 16:16
  Is the space allocated for menus fixed?By Board Room in forum Authoring (DVD)Replies: 2Last Post: 8th Jul 2010, 11:31
  Why am I losing so much disk space?By Han Solo1 in forum ComputerReplies: 7Last Post: 24th Nov 2008, 21:17
  Hard Disk Space When EncodingBy Em in forum Newbie / General discussionsReplies: 8Last Post: 21st May 2007, 13:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
