Is it a hack that makes a DVD player able to play DIVX files or is it something the manufacturer does? If it is a hack, Is there one for the Kawasaki 10921?
or IOW there has to be hardware in the player so either buy a new player that supports Divx/Xvid or encode to DVD spec, author and burn as a DVD.
You can see a list of Divx capable players to the left: https://www.videohelp.com/dvdplayers
Just select Divx in the checklist and you will see some compatible players. There are some inexpensive ones available at some of the chain stores like Walmart or similar. There are some that are around $50US and they will also play a regular DVD.
And welcome to our forums.
DivX DVD Players
By jm in forum DVD & Blu-ray PlayersReplies: 5Last Post: 28th Feb 2008, 19:30 -
dvd players with DivX playback?
By iThinkYouBrokeIt in forum DVD & Blu-ray PlayersReplies: 9Last Post: 5th Nov 2007, 18:52 -
DivX players that play HD divx files
By russeverett in forum DVD & Blu-ray PlayersReplies: 7Last Post: 6th Oct 2007, 03:18 -
Divx DVD players
By greer1988 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 24th Aug 2007, 07:57 -
DivX DVD Players
By boshu22 in forum DVD & Blu-ray PlayersReplies: 13Last Post: 9th Jun 2007, 21:54
