Hi,
I am trying to capture my tapes to digital formats and write them to DVD disks so they won't degrade. Have both 8mm analog tapes from a 1991 RCA Pro8 camcorder and miniDV tapes. My goal is to keep as much resolution as practical to preserve the memories. Please help with your comments and guidance.
*miniDV tapes (below is what I've been playing with)
Firewire to computer hard drive using Ulead and AVI format (13GB for 1 hour)
Export movie to MPEG2 720x480 variable bite rate of 4700bps using all I, B, and P frames. I get about 4.6GB for 2 hours of video. Just fits on 1 DVD disk.
Questions:
1. Anything else better if I would like to live under the 2 hour per DVD disk constraint?
2. What options do I have if I am willing to do 1 hour per DVD disk? Should I just increase the bit rate of MPEG2 or there are AVI compressions that I can use that can give me lossless results?
*8mm analog tape
I need a lot of help here. I assume the best way is still capturing in lossless AVI format and then do the processing later offline. What resolution should I use for capturing? What sound quality? I assume that it's useless to capture at a resolution higher than the original soure, and it's best to match the source so there is no aliasing effects. Is that right? The camcorder spec says 525 lines/60 fields/30 frames and EIA Standard NTSC color. Doesn't look like the NTSC TV resolution. I need help in understanding what it means to the capturing settings.
Thanks a lot.
Results 1 to 1 of 1
Encoding with higher resolution doesn't preserve quality.
By aznstriker92 in forum Video ConversionReplies: 50Last Post: 2nd Oct 2009, 13:38 -
Convert DVD to Xvid using original resolution
By iBeech in forum Video ConversionReplies: 5Last Post: 13th Jan 2009, 10:05 -
Original AVI destroyed. Need to edit MPEG-2 and preserve quality
By neophyte in forum Newbie / General discussionsReplies: 4Last Post: 30th Nov 2008, 17:41 -
Can you preserve HD/Blu-ray's original quality at 4/8gb?
By broaddd in forum Blu-ray RippingReplies: 1Last Post: 30th Mar 2008, 06:46 -
How to Preserve DVD Resolution in mp4
By dizzie in forum Newbie / General discussionsReplies: 4Last Post: 4th Sep 2007, 11:18
