Results 1 to 9 of 9
    Sep 2005
    North America
    I have 16x disks and wonder if it is "safe" to burn a movie at that speed? Will the movie play alright?
  2. Banned
    Feb 2005
    USA
    Some people say yes. Some people say no. I personally have no problems burning anything at 16x.
  3. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    If disks are rated at 16X, there should be no problem. Ive burnt numerous disks at 16X without any problems.
    Mar 2004
    Boise, ID
    amen (or I agree).
    Your burner and/or software won't let you burn it that fast, unless it thinks it can handle it.
    Rob
  5. Banned
    May 2006
    Chicago suburbs
    I have no trouble burning them at that speed, but they won't always play in standalone players.
  6. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    I normally burn all my blanks at 8x, they are rated for 12x and 16x, but time is not an big issue for me...
    Sep 2005
    North America
    Thank you all for your replys. They have been very helpful.
    Dec 2004
    Australia
    Burn at say 8X and 16X, then scan with say KProbe or Nero CD Speed and compare.
    Any decent quality 16X discs should be fine at 16X. Also depends on the burner though.
  9. It only peaks at 16x anyway, most of the time it's slower.
