When I capture HDV, edit it with Adobe Premiere Pro 1.5 and render it out, the picture is all funky looking, or when it gets put it onto DVD it's all distorted or the video is blank!!! PLEASE help me out here!
My setup:
Sony HDR-HC3, capturing with 1394 IEEE firewire.
Adobe Premiere Pro 1.5, using the CineForm HDV codec.
P4 3.0 GHZ, 1.0 gb ddr ram.
I understand that you cannot put HDV onto a regular DVD. However, I want to get the best looking picture possible. (Hence the fact that I blew $1500 on a High Definition Camcorder.) Please respond with some sort of help!!! I'm in dire need!
Thanks.
distorted? how?
so you render to dvd mpeg with premiere pro? and authoring and burning with?
are you exporting to NTSC?
does the burned dvd work on your computer with a software player? -
It seems as if the aspect ratio is incorrect. (i.e. It's competely square instead of widescreen.) It's also blipping every few seconds. Very odd. Even before I put it on DVD it looks like that. The footage looks the same on the dvd whether I play it on my tv or my pc.
After exporting to dvd mpeg i use tmpgenc dvd source creator and dvd author to get it onto a dvd, which to me seems like it lessens the quality of the footage. If there is a better program or method of getting it from premiere to dvd, please let me know. Thanks again.
P.S. I love Baldrick. -
I've tried rendering out at different aspect ratios but they all don't look right. The only way I could get it to have the right ratio was to capture it as microsoft dv avi. The quality, compared to HDV, is horrible. I won't be back to respond to this for about 8 hours.
HV40: Record in HDV(PF24) vs HDV(24F)
By videobread in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 23rd Dec 2011, 21:44 -
Best render settings for DVD in Vegas
By harishfx20 in forum EditingReplies: 4Last Post: 11th Aug 2010, 02:16 -
Every DVD I render has ugly color
By DrGori in forum ffmpegX general discussionReplies: 2Last Post: 12th Apr 2010, 15:28 -
From HDV shooting to HDV watching
By MI6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th Apr 2008, 14:05 -
HDV to DVD
By PeterK in forum Video ConversionReplies: 7Last Post: 13th Jun 2007, 20:01
