I want to burn my video capture from my DV camcorder to a DVD disk and show it in better quality on my TV than 480i offers. I have a Samsung HLR5067W with HDMI and its native resolution is 720p. I don't want to reduce the resolution of the DV caputure to 480i and then upconvert. Can I save the capture to high quality DIVX and maintain most of the original resolution - at least much more than 480i. My present DVD player won't handle it, but I'd buy an Oppo 970 or 971 if it could get better resolution. I'd like to know my alternatives. I'd rather not keep the finished product as avi, as I want to reduce file size...so sending the signal from my PC to the Tv is not a consideration. Any suggestions?![]()
720x480 DV capture becomes 640x480 on your TV (when authored as DVD). If you have a means of connecting your computer to your TV, 640x480 is as good as it gets with your source material.
Which DV camcorder do you have? It is unlikely that you are starting with even 720x480i resolution. If this is a high end camcorder, the HDTV will do the best job upscaling from a 720x480i DVD. Your Samsung HLR5067W DLP should like 480i as an input.Originally Posted by DokSoul
M-JPEG (HD-) files to show on HDTV
By haschopapa in forum Video ConversionReplies: 3Last Post: 24th Dec 2009, 08:03 -
Poor Quality Out of TV Show Rips
By ajedale in forum Newbie / General discussionsReplies: 8Last Post: 21st Jun 2009, 21:11 -
digital HDTV + DVD recorder show own DVD files?
By Tblossom in forum Newbie / General discussionsReplies: 2Last Post: 9th Dec 2008, 11:56 -
Want to Create Slideshow DVD to show on My HDTV
By 1deciple in forum Newbie / General discussionsReplies: 0Last Post: 7th Jul 2008, 16:54 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 06:50
