hi,
i've got a problem.
some of my movies are svcd files (2 cd's) and i wanna look those on my standalone dvd player at home.
i'm not able to look because my player doesn't support it.
ok i have the software tmpgenc. and wanna know how to ecode,convert (whatever) it into a vcd file.
please let me know it step by step because my english isn't so good.
the prog is in english and i don't know the meaning of some words!
thanx in advance.
greetings
spunky
What is your language? I speak portuguese...
what is your file format? AVI or MPEG?
Do you know TMPEGEnc software? Or Ulead DVD Factory? Both converts files from one format to other... -
this guide will help you with TMPGEnc...
http://www.vcdhelp.com/tmpgenc.htm
it does include pictures that might help you understand where the language fails.
to help more with translating you might want to try this page...
http://www.altavista.com/r?F09
one last thing is you may need to install the MPEG-2 codec to work with SVCD files. get it here...
http://www.dvd-wizards.com/vcdhelp/mpeg2codec_installer.zip
peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 10:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 08:34 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 10:27
