Just wondering what people are using to backup dvd's to the pc and then burning them to dvd-r. I was using just dvdfab but for some reason my dvd's don't play in my standalone anymore. Then from what I've been reading, backing up the dvd first to the hdd gives you a better chance the movie will play.
If anyone has a good method of backing up dvd's and a good program to burn it... please let me know. I prefer to keep the movie uncompressed... so any programs to get the backup on to 2 dvd-r's, will be much appreciated.
Thankyou
Try the "ALL GUIDES" section to your left and you will find:
https://www.videohelp.com/guides.php?guideid=604&howtoselect=6;30#604
https://www.videohelp.com/guides.php?guideid=481&howtoselect=6;30#481
https://www.videohelp.com/guides.php?guideid=323&howtoselect=6;30#323
https://www.videohelp.com/guides.php?guideid=248&howtoselect=6;30#248
You may also achieve what you want by using something like VOBBlanker to remove unwanted material, which may allow you to keep the entire movie uncompressed. You can also use DVDShrink in reauthor mode and the Start/End feature to split the main title at a point such that no compression is applied.If in doubt, Google it.
All-in-one PAL-DVD to NTSC-DVD programs?
By mijman in forum Video ConversionReplies: 1Last Post: 15th Jan 2012, 22:35 -
DVD Shrink-like programs
By technicolornightmare in forum Newbie / General discussionsReplies: 9Last Post: 23rd Oct 2010, 09:45 -
Dvd programs for windows 7
By tansdad in forum Newbie / General discussionsReplies: 1Last Post: 14th Feb 2010, 16:39 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 16:51 -
Noob: How to put to DVD programs on to one DVD disc?
By peggypwr1 in forum Newbie / General discussionsReplies: 6Last Post: 23rd Mar 2009, 13:48
