Hi,
I am working with a digital video camera, and the frame size is 720x576. I have created my video file(premiere), and output it to an AVI(using the Canopus Corp Rapter Card Codec), to an avi. Using the Canopus codec, i get no loss of quality.(frame size is 720x576)
I want to create a SVCD, but I am confused about this. The SVCD frame size is 480x576, the AVI footage is 720x576. If I want to create my output avi in the right frame size for CCE MPEG encoder, it would seem that my video will be half the size(720 down to 480) in width, but the same height(576).
Would this not look stupid. I exported part of a video, and it did look stupid. All squished!
Am I going about this wrong ?
Peter
480x576 is the standard SVCD PAL resolution. Play the SVCD with a standalone dvd player and it will be displayed (stretched to) full screen.
Make sure you select the proper displayed aspect ratio.
<font size=-1>[ This Message was edited by: Truman on 2002-01-06 13:04:17 ]</font>
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Standard XVID Frame Sizes
By adalect in forum Newbie / General discussionsReplies: 15Last Post: 16th Apr 2010, 00:11 -
Project with mixed frame rates and resolutions - confused
By tarrickb in forum Video ConversionReplies: 4Last Post: 10th Aug 2009, 14:38 -
Do I need to change AVI frame sizes before convertx to DVD
By johnharlin in forum Newbie / General discussionsReplies: 6Last Post: 18th Nov 2008, 19:58
