Results 1 to 12 of 12
  1. Member JConnor's Avatar
    Apr 2006
    Bulgaria
    The application failed to initialize properly (0xc0000135). Click on Ok to terminate the application.
    Does someone know how come i get this error everytime i try to start SubtitleCreator and maybe how ti fix it???
  2. .net framework? IIRC v 1.1
  3. Member JConnor's Avatar
    Apr 2006
    Bulgaria
    Even without those i still got the same problem...
  4. Originally Posted by JConnor
    I think you didn't understand. SubtitleCreator require .net framework to work. I think version 1.1 you need to install on your computer.
  5. Member JConnor's Avatar
    Apr 2006
    Bulgaria
    Application has generated an exception that could not be handled.
    Proces id=0xfd4 (4052), Thread id=0xe84 (3716).
    Click OK to terminate the application
    Click Cancel to debug the application.
    This is after i installed frameworks 1.1 ? Any other ideas?
  6. The root of all evil träskmannen's Avatar
    May 2005
    Belgium
    A good idea would be to install .NET Framework instead. It is something completely different from frameworks.
  7. Member JConnor's Avatar
    Apr 2006
    Bulgaria
    Excuse me i mixed up their names. The thing i installed is Microsoft .NET Framework 1.1
  8. The root of all evil träskmannen's Avatar
    May 2005
    Belgium
    Sorry, cant help you on this one but try posting in http://forum.doom9.org/showthread.php?t=80109. The author of the program uses that thread for bug-reports etc.
  9. Member JConnor's Avatar
    Apr 2006
    Bulgaria
    thanks i will check it out.
  10. This was already reported there, but there is no solution by now (look at the page 18 ). Maybe try to install an older version (I am using 1.9.0) and use installer (.msi)
  11. Member JConnor's Avatar
    Apr 2006
    Bulgaria
    I juste re-downloaded it and now it works perfectly
    Jan 2004
    Australia
    As the author of SC, I can tell you that the latest release (a week old, v2.0.1 RC1) uses the .NET v2 framework, and as indicated above, the previous versions (till 1.9.2) require the .NETv1.1 framework.
    Author of SubtitleCreator
