    Jun 2006
    I'm having an intersting symptom and I'm wondering if anyone has suggestions as to where to start troubleshooting.
    Basically while I'm filiming I notice that there is this random flickering in the LCD viewfinder. It is also there when I go to play back the tape either on the camera or after I upload it into my computer. I don't think it's dirty heads because I've been told that dirty heads look more like a TV with a bad reception. This flickering looks a lot more like the way a VHS tape looks when it needs the tracking adjusted (that's the closest comparison I can make).
    I'm wondering if this is an issue with my camera because it did the flickering with the next tape I put in (although I should mention that it was the same BRAND of tape - Maxell Mini DV DVM60SE). Should I try a different brand? I never had this problem before with Maxell tapes.
    My camera (and don't laugh) is a JVC Model: GR-D90U
    Any suggestion anyone has as to what this flickering is would be appreciated.
    Thanks,
    Dustin
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Thanks,
    Dustin
    Does this show up when played to a TV?
    If you play a known good tape from the past does it show the same flicker?
    Are you sure you aren't in a special mode? Try to reset the camcorder or remove the battery overnight to reset modes. A hard reset would require removing the cmos battery.
