Question #1
If you have a movie file, with what can you see what kind of player you need too play the file?
Question #2
What player can play the most of the movie files?
Question #3
When you have downloaded a codec file what do you do with it so it works?
Question #4
I have a movie file, It is an avi and first time I started it I open it with media player classic and next time when I started it it came up a message “Cannot render the file.” Even I started it wth the same software as the first time.
Why? What have happened?
What can I do to fix it?
Some short answers:
#1 - Gspot (get the newer beta version)
#2 - VLC (has its own codec supply) or MediaPlayerClassic (may need add'l codecs to download)
#3 - Don't download a codec unless you are certain you need it (IOW, avoid the "Paks"). It should come with an installer and instructions.
#4 - Hard to track this down without knowing further info: Media type & contents, OS version, DX version, which codecs installed, etc.
Scott -
1. At first I try to look at the file extension. Then - GSpot to see if I have successful rendering (and ofcourse codec, but for example, I can play an avi encoded with divx3 and GSpot said me the codec is not instaled)
2. the same
3. I would suggest to install ffdshow. It cover the majority of decoders. This is what you need to play the file - not really codec but directshow decoder (or filter).
4. drop the file in GSpot to see if you can render it.
3d questions
By alucard2050 in forum DVB / IPTVReplies: 16Last Post: 21st Aug 2010, 23:01 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 15:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 18:08 -
Some Yes or No questions
By the_importer in forum Media Center PC / MediaCentersReplies: 22Last Post: 3rd Jul 2008, 18:06 -
Got a new 16:9 TV, have some questions...
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 28th Jul 2007, 14:00
