Well here i go
Has anyone tried burning a dvd over a network ???
to elaborate
the dvd video folder is on 1 computer and i will like to know if if it would work if i open nero on
another computer and direct it to the files on the first or rather transfer it over to one of the other system then burn
the reason i asked is that my files are stored on my faster system pentium 4 3.4 2 ghz ram which i
use for
encoding and authoring which i dont like stopping to do other tasks such as burning. plus I am
afraid of having bad burns sinch all the programs demand high resources
should i set up a network and output the files from my authoring programs to my other
systems 2 ( pentium 4 2.2 1 ghz ram)
and burn them there ??
Or direct NERO to the files on the first system then burn from there over the network
i dont have a router yet but i am looking to get a gigabyte one.
What would you do
I presently tranfer the files using a 40 gig hard drive in a portable enclosure
Yes
I have
done that
before
but i havent
dont it in
a
while. i did
it back when i
was burning
at
4x speed.
i'm not sure
how it would work
at 16x
but the
dvd-r's
are cheap enough
that you could
give one
a shot.
good
luck.
No problem if both pc's a relatively fast ... but this method really is not recommended , as you are adding another step ... which could "blink" at any time during the process ... with modern burner's this is nolonger an issue , as they wait ...
I use this method under "extreme" condition's ... backing up failing hd's from one pc to another ... effectively imaging the drive before it crap's out .
In your situation , best transfer a "copy" of the file's to the other pc ... once over there , you can delete the original back on the original pc ... -
Many burning programs can automatically copy network files to the local machine before starting to burn. But I burn from network shares all the time without it. I do limit the burn speed to 8x though.
Specific system needed for AVCHD1080 -> DVD - suggestions please!
By Telek in forum Newbie / General discussionsReplies: 19Last Post: 10th Mar 2010, 15:17 -
New Camcorder Suggestions Needed
By wangy26 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 6th May 2009, 16:28 -
Wanna buy a new PC & TV Out card, suggestions needed.....
By SE14man in forum Newbie / General discussionsReplies: 0Last Post: 9th Nov 2007, 20:22 -
Need suggestions on capturing satellite output from Dish Network
By Mordimar in forum DVB / IPTVReplies: 3Last Post: 31st Oct 2007, 10:36 -
burning over a network
By Hal05154 in forum DVD & Blu-ray WritersReplies: 3Last Post: 7th Aug 2007, 14:11
